Date/Time: Sat, 18 May 2024 13:54:15 +0000
In Replay mode using Ultimate Oscillator hangs the chart
View Count: 549
[2020-06-08 14:35:41] |
User189132 - Posts: 63 |
Hi, In replay mode with Ultimate Oscillator study and following settings: Speed : 120 Jump time unit: 30 minutes Bar Period type: 0-600-0 Days to load: 60 After around 3 trading hours of replay the chart hangs with mouse pointer becoming circle and does not come out of it. I do not do/touch anything. Without the study chart works/replays fine. I also tried in Safe mode as well with the same result. Please advise. Date Time Of Last Edit: 2020-06-08 14:46:21
[2020-06-08 19:03:45] |
Not sure why you are having an issue but we did add some division by zero checks for this study. And we are not noticing the problem. Wait for the next release and see if that helps.
[2020-06-09 10:26:16] |
Re>"Not sure why you are having an issue but we did add some division by zero checks for this study. And we are not noticing the problem." I can provide my chart definitions and symbol, you can debug and see what happens. I ran into the same issue with "Momentum with Moving Average" and "Stochastic Fast" studies. I did not check whether both causing the issue or one of them, can you check? Re>"Wait for the next release and see if that helps. " What's the planned release date? |
