Date/Time: Sat, 18 May 2024 11:01:43 +0000
Denali upgrade combined with 32 bit PC
View Count: 512
[2020-06-08 14:11:48] |
bootsy - Posts: 63 |
Hi there, Am currently running a 32 bit machine which has served me well over the years with an SSD upgrade. Am using a Denali data feed. Have just seen the message that I need to upgrade my SC charts to version 2060 before June 15th to continue using the Denali feed. I am currently running (according to SC) Version 2021 32 bit. Therefore I obviously need to upgrade my SC chart version! However I seem to remember that something is going on with SC no longer doing builds for 32 bit machines so, simple questions: 1) Can I upgrade to version 2060 and still continue to use SC on my 32 bit machine or will I be upgrading to a version that is incompatible with my 32 bit machine? 2) Depending on the answer to 1), is there any way I can continue to use SC and denali/any data feed with my 32 bit machine? It works fine and to have to bin it and buy a whole new PC and monitors that all still function perfectly well will obviously be a huge cost and pretty bad wastage for the environment too. Thanks, Bootsy |
[2020-06-08 19:02:54] |
You can still upgrade to the current version and get the 32-bit executable. We have not stopped delivering it yet. We will one of these days, but it has not happened yet.
