Date/Time: Fri, 24 May 2024 06:57:27 +0000
Displaying Net Change on Compact Tool Values Window
View Count: 1061
[2020-06-08 03:46:10] |
User139520 - Posts: 26 |
Dear, I would like to see the Net Change which shows the tick size of a candlestick. It doesnt seem that mine is showing. How do I enable it? Thank you, |
Compact Tool Values Window.PNG / V - Attached On 2020-06-08 03:42:06 UTC - Size: 102.63 KB - 262 views |
[2020-06-08 16:01:31] |
Ackin - Posts: 1865 |
Try: Study Bar Difference Bar Difference The Compact Tool Values Window displays the value for each Subgraph for the first study or the main price graph in the Chart Region that you are currently pointing to when using one of the Drawing Tools.
When using Compact tool as in the main chart, when you place the cursor in the region you will see the tick size Date Time Of Last Edit: 2020-06-08 16:01:51
[2020-06-08 19:00:55] |
You need to use the Tool Values Window to see that field: Window and CW Menus: Tool Values Window (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
