Date/Time: Sat, 18 May 2024 13:53:52 +0000
Sierra chart update
View Count: 555
[2020-06-08 00:21:23] |
User161549 - Posts: 81 |
I received a notification a week or so back stating an update was needed on my current version of SC Can you tell me what version I am currently using and what is the most recent version up to date ? Also will the update affect any of my chartbooks/ layouts/ or performance issues as far as data routing ? |
[2020-06-08 01:49:33] |
You are using version 2028 and you definitely do need to update. Instructions: Software Download: Fast Update Also will the update affect any of my chartbooks/ layouts/ or performance issues as far as data routing ? No.
[2020-06-08 19:14:07] |
I followed the steps in the forum and have updated my SC Can you confirm that in fact I have updated it correctly and that I am up to date with any other recent updates I might not be aware of Thank you |
[2020-06-09 01:46:16] |
Yes you are all set. You are up-to-date and good.
