Date/Time: Sat, 18 May 2024 13:22:44 +0000
Number Bar
View Count: 509
[2020-06-06 12:00:08] |
User999835 - Posts: 28 |
Hello, Is it possible to add dots/cross/etc within a number bar to signal certain conditions have been met (at each price rather than above/below the candle)? I understand it is possible to color each price within the number bar (based on tresholds etc) but in addition to colors would it be possible to add dots to add different types of tresholds? Thank you |
[2020-06-06 14:01:58] |
cmet - Posts: 538 |
If what you're trying to track are based on volume at a particular price, you can use the Volume at Price Threshold Alert studies. These allow you to place markers intrabar.
[2020-06-08 18:53:59] |
Have a look at this study: Volume at Price Threshold Alert V2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
