Date/Time: Tue, 14 May 2024 10:27:03 +0000
Trade Window
View Count: 477
[2020-06-05 14:30:56] |
Monserrate G - Posts: 27 |
I downloaded platform and by default trade window is showing orders for 10, 20, 30, etc amount of contracts. How do I reconfigure the trade window. I did not find anything under trade window in Help section. Thank you
[2020-06-05 14:41:41] |
User75002 - Posts: 117 |
On the trade window, click on the Set tab. Quantities are at the bottom. Once you have them set, go back to the Main tab, click the M button and then Save Configuration.
[2020-06-05 18:42:31] |
For what symbol do you notice those order quantities with? To change the order quantity of the quantity buttons, refer to: Basic Trading and the Trade Window: Main/C >> Order Quantity Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-05 18:42:47
