Date/Time: Tue, 14 May 2024 03:18:26 +0000
GBP/SEK and GBP/NOK
View Count: 589
[2020-06-05 10:03:20] |
User160486 - Posts: 36 |
I am unable to find the following currency pairs: GBP/SEK and GBP/NOK. Are they available? If not, could you make them available?
[2020-06-05 10:27:57] |
These are available through the supported LMAX exchange: LMAX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-05 15:29:36] |
Thank you. I was referring to getting the charts for the aforementioned currencies like I do with all the other pairs. How do I do that?
[2020-06-05 18:36:04] |
You can access those pairs by creating a LMAX demo account and then we can assign that account to your Sierra Chart account and then you will have access to the data within Sierra Chart. The LMAX demo data is quite similar to the real-time data. Instructions are on the page we linked above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-05 18:36:26
