Date/Time: Tue, 14 May 2024 16:32:34 +0000
multiple selection in trade activity
View Count: 457
[2020-06-04 19:21:39] |
User884550 - Posts: 149 |
is it possible multiple selection in trade activity filters? for example I want to filter by 3 symbols instead of 1 or all of them if not, can it be implemented? also, are you planning some sort of journaling implementation? |
[2020-06-04 23:49:41] |
No this is not currently supported right now. Yes journaling is going to be added at some point. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
