Date/Time: Sat, 18 May 2024 11:28:53 +0000
daily loss stop lost
View Count: 501
[2020-06-04 17:41:42] |
AndyB - Posts: 96 |
hi, is it possible to automatically set a stop to my daily loss limit? this is mostly so i can visualize my risk. i'd like it to update when contracts are added to a position. 2. i cant seem to figure out if its possible or not to set my daily loss to a percentage of my overall account. calculating this on the fly is tough, and i'm a much more visual trader. thank you! A |
[2020-06-04 23:44:11] |
Well it is certainly possible to use Stop Attached Orders: Attached Orders 2. No this is not supported at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
