Date/Time: Fri, 10 May 2024 15:30:58 +0000
Trade Order Error - Selected Time in Force is not supported.
View Count: 801
[2020-06-03 15:14:50] |
User686874 - Posts: 2 |
Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2020-02-26_UTC.data | 2020-06-03 11:10:43.743 * Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2020-01-28_UTC.data | 2020-06-03 11:10:43.756 * TradeActivity files query time: 0.071140 seconds. Entries: 0. Current queries: 2 | 2020-06-03 11:10:43.763 TradeActivity files query time: 0.009959 seconds. Entries: 607. Current queries: 1 | 2020-06-03 11:10:43.773 Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2020-01-28_UTC.data | 2020-06-03 11:12:54.702 * Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2020-02-26_UTC.data | 2020-06-03 11:12:54.709 * TradeActivity files query time: 0.187354 seconds. Entries: 622. Current queries: 1 | 2020-06-03 11:12:54.880 TradeActivity files query time: 0.013397 seconds. Entries: 149. Current queries: 1 | 2020-06-03 11:13:08.448 TradeActivity files query time: 0.010007 seconds. Entries: 149. Current queries: 1 | 2020-06-03 11:13:17.256 Trade Order Error - Selected Time in Force is not supported. Internal Order ID: 129. Service Order ID: (none). Symbol: F.US.MESM20. Account: 122307 | 2020-06-03 11:14:01.387 * Date Time Of Last Edit: 2020-06-03 15:15:23
[2020-06-03 18:05:11] |
What is the time in force that you are using? Refer to this setting: Basic Trading and the Trade Window: Main >> TimeInForce (Time in Force): Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-03 18:05:40] |
You need to use a different Time in Force option, as the one that was selected for the order that got rejected was not valid for the exchange. Refer to the information here: Basic Trading and the Trade Window: Main >> TimeInForce (Time in Force): ------------ Also, according to the Message Log you supplied, you have a few Trade Activity Logs that are incomplete. You can just delete these files. They are the following: TradeActivityLog_2020-01-28_UTC.data TradeActivityLog_2020-02-26_UTC.data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
