Date/Time: Sun, 19 May 2024 21:31:27 +0000
Draw Volume Profile tool issue in v9
View Count: 623
[2020-06-03 12:58:58] |
User549147 - Posts: 2 |
Hello, I just updated my SC installation to version 9 and now my custom settings for the 'draw volume profile tool' aren't saving. I'm updating the tool settings and checking the box to 'save these settings as the default', hitting apply and ok... but the next time I go to draw a profile it reverts to using the default settings. My custom default settings don't apply to new profiles. I'm using version 2115 Is there anyway I can fix? Thanks Date Time Of Last Edit: 2020-06-03 13:05:56
[2020-06-04 07:30:31] |
This has to be done a little differently now. Refer to the following information for how to have custom settings for use with the Drawn Volume Profile: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-04 07:31:19
