Date/Time: Sun, 19 May 2024 17:10:59 +0000
Entering a batch of different orders together
View Count: 482
[2020-06-02 14:45:59] |
User553301 - Posts: 3 |
Hi Support, Is there an easy way to send a batch of market orders for different products in one click. Example: buy market /es buy market /nq buy market /ym and send them all together so they all hit the market as market orders at the same time? Thank you, Renn |
[2020-06-02 19:46:01] |
You could use this study for that: Spread Order Entry Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-03 19:59:30] |
Thank you :-) I did see that study. I guess I'm looking for a more manual entry. Example code for a simple DOM order entry where I could input two symbols and hit Buy Market button or sell market button. Is there sample code for order entry - I could just copy that to add the extra symbol and I think that would work Thank you, R |
[2020-06-04 07:07:51] |
The other way is to use a custom study. Refer to: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
