Date/Time: Fri, 10 May 2024 16:36:48 +0000
configuration
View Count: 465
[2020-06-01 21:40:59] |
User691398 - Posts: 27 |
I am fairly new to SC, I need some help in configuringt SC. I need to configure sierra chart to connect to CQG (using for data feed) to access Interactive brokers IB. I know how to configure SC using IB data feed. (at Data/Trade Service Settings, choose Interactive Brokers) it works fine even without IB data feed as long as I use sierra chart data feeds, with (Allow Support for Sierra Chart Data Feeds box is checked) but I need to use CQG data feed. Similar I choose at Data/Trade Service Settings CQGWebAPI, don't know how to connect IB connection. I know you would like me to use Denali data feed, but I need to use CQG. I am not asking you to support CQG nor IB all I am asking how to configure communication between CQG and IB. Thanks in advance. g |
[2020-06-02 04:49:36] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
