Date/Time: Fri, 10 May 2024 05:24:42 +0000
DOM header box color settings
View Count: 499
[2020-06-01 18:09:12] |
User425645 - Posts: 113 |
Hello, how do I locate and change the color for my DOM header? I will post a picture below with an arrow pointing to what I am referring too - thanks.
Capture.PNG / V - Attached On 2020-06-01 18:09:03 UTC - Size: 148.48 KB - 201 views |
[2020-06-02 04:20:37] |
The first thing we want you to do is to update to the latest prerelease 2115: Software Download: Fast Update And then if you still have a problem provide a screenshot: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
