Date/Time: Wed, 18 Nov 2026 09:19:01 +0000
Broblem with connection to rithmic trading, no problem before.
View Count: 822
| [2020-06-01 16:23:19] |
| Artur KaĆtoch - Posts: 3 |
Account Name: Artur1981 User Message: I cannot connect with rithmic, had no such problems before. ---------------------------------------- Selected Data/Trading service: Rithmic Trading ---------------------------------------- Log: Reading Internal Order ID file. | 2020-06-01 13:18:41.105 Reading Trade Orders file. | 2020-06-01 13:18:41.150 Reading Trade Positions file. | 2020-06-01 13:18:41.150 Reading Account Balance file. | 2020-06-01 13:18:41.150 UDPListener (1440). Port 22904 | Listening on UDP port 22904. | 2020-06-01 13:18:41.159 Software version: 2115 64-bit | 2020-06-01 13:18:41.160 Primary Thread ID: 10928 | 2020-06-01 13:18:41.160 Usage end date: 2020-07-02 | 2020-06-01 13:18:41.160 Enabled for: Advanced Features 2. | 2020-06-01 13:18:41.160 Enabled for: Sierra Chart Historical Data Service. | 2020-06-01 13:18:41.160 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-01 13:18:41.160 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-01 13:18:41.160 Current selected Data/Trading service: Rithmic Trading | 2020-06-01 13:18:41.160 Custom symbol settings values: enabled | 2020-06-01 13:18:41.160 Chart Update Interval: 500 | 2020-06-01 13:18:41.160 Intraday Data Storage Time Unit: 0 | 2020-06-01 13:18:41.160 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2020-06-01 13:18:41.160 2020-06-01 13:18:41 Local computer time | 2020-06-01 13:18:41.160 2020-06-01 11:18:41 Local computer time in UTC | 2020-06-01 13:18:41.160 2020-06-01 13:18:41 Local computer time in SC Time Zone | 2020-06-01 13:18:41.160 2020-06-01 11:18:38 Server time in UTC | 2020-06-01 13:18:41.160 Local computer UTC time and Server UTC time difference: 2 seconds. | 2020-06-01 13:18:41.160 Program path: C:\SierraChart\ | 2020-06-01 13:18:41.160 Data Files path: C:\SierraChart\Data\ | 2020-06-01 13:18:41.160 OS Version Number: 10.0 | 2020-06-01 13:18:41.160 Locale Setting: C | 2020-06-01 13:18:41.160 Allowed protected custom studies: | 2020-06-01 13:18:41.160 Created the DTC Protocol server. | 2020-06-01 13:18:41.161 DTC Protocol Server listening on port 11099. | 2020-06-01 13:18:41.162 Created the DTC Protocol historical data server. | 2020-06-01 13:18:41.162 HD Server Manager | Listening on port 11098 | 2020-06-01 13:18:41.163 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-06-01 13:18:41.163 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 13:18:41.249 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-06-01 13:18:41.306 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-06-01 13:18:41.306 Received 5 login tokens. | 2020-06-01 13:18:41.375 Symbol settings MD5 received. Request ID: 1. | 2020-06-01 13:18:41.535 Symbol settings are up-to-date for rithmic.trading. | 2020-06-01 13:18:41.535 Rithmic Trading | Port for executable: 50381 | 2020-06-01 13:18:46.486 Listening socket (1072). Port 50381 | Closed. | 2020-06-01 13:18:46.486 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 13:18:46.490 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50381. Current folder: C:\SierraChart\Rim | 2020-06-01 13:18:46.522 Rithmic Trading | Bridge process is running. | 2020-06-01 13:18:48.525 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50381 | 2020-06-01 13:18:48.525 DTC Client socket (1) | Creating socket. | 2020-06-01 13:18:48.525 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 13:18:48.525 Rithmic Trading | Connected to server. | 2020-06-01 13:18:48.527 Rithmic Trading | Starting socket receive thread. | 2020-06-01 13:18:48.527 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 13:18:48.529 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 13:18:48.530 Rithmic Trading | Sending logon request message. | 2020-06-01 13:18:48.530 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 13:18:48.533 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 13:18:48.537 Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-01 13:18:48.537 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 13:18:49.738 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 13:18:50.350 Rithmic Trading | Received logon response. | 2020-06-01 13:18:50.350 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 13:18:50.350 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 13:18:50.350 Rithmic Trading | Logon error received from server | 2020-06-01 13:18:50.350 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 13:18:50.350 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:18:50.350 DTC Client socket (1) | CloseSocket call. | 2020-06-01 13:18:50.401 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 13:18:50.401 Rithmic Trading | Disconnected. | 2020-06-01 13:18:50.402 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:18:50.402 Rithmic Trading | Port for executable: 50395 | 2020-06-01 13:18:52.406 Listening socket (1000). Port 50395 | Closed. | 2020-06-01 13:18:52.406 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 13:18:52.409 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50395. Current folder: C:\SierraChart\Rim | 2020-06-01 13:18:52.446 Rithmic Trading | Bridge process is not running! | 2020-06-01 13:18:54.449 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50395 | 2020-06-01 13:18:54.449 DTC Client socket (2) | Creating socket. | 2020-06-01 13:18:54.449 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-01 13:18:54.449 DTC Client socket (2) | Connect event error. Windows error code 10061: Nie mona nawiza poczenia, poniewa komputer docelowy aktywnie go odmawia. | 2020-06-01 13:18:56.453 * DTC Client socket (2) | CloseSocket call. | 2020-06-01 13:18:56.454 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 13:18:56.454 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:18:56.454 DTC Client socket (2) | Closed. | 2020-06-01 13:18:56.454 DTC Client socket (0) | CloseSocket call. | 2020-06-01 13:18:56.461 Rithmic Trading | Disconnected. | 2020-06-01 13:18:56.462 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:18:56.462 Rithmic Trading | Port for executable: 50399 | 2020-06-01 13:18:58.483 Listening socket (1088). Port 50399 | Closed. | 2020-06-01 13:18:58.483 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 13:18:58.486 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50399. Current folder: C:\SierraChart\Rim | 2020-06-01 13:18:58.518 Rithmic Trading | Bridge process is not running! | 2020-06-01 13:19:00.512 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50399 | 2020-06-01 13:19:00.512 DTC Client socket (2) | Creating socket. | 2020-06-01 13:19:00.512 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-01 13:19:00.512 DTC Client socket (2) | Connect event error. Windows error code 10061: Nie mona nawiza poczenia, poniewa komputer docelowy aktywnie go odmawia. | 2020-06-01 13:19:02.516 * DTC Client socket (2) | CloseSocket call. | 2020-06-01 13:19:02.516 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 13:19:02.516 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:02.517 DTC Client socket (2) | Closed. | 2020-06-01 13:19:02.517 DTC Client socket (0) | CloseSocket call. | 2020-06-01 13:19:02.523 Rithmic Trading | Disconnected. | 2020-06-01 13:19:02.523 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:02.524 Rithmic Trading | Port for executable: 50402 | 2020-06-01 13:19:04.530 Listening socket (1000). Port 50402 | Closed. | 2020-06-01 13:19:04.530 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 13:19:04.532 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50402. Current folder: C:\SierraChart\Rim | 2020-06-01 13:19:04.563 Rithmic Trading | Bridge process is not running! | 2020-06-01 13:19:06.555 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50402 | 2020-06-01 13:19:06.555 DTC Client socket (2) | Creating socket. | 2020-06-01 13:19:06.555 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-01 13:19:06.555 DTC Client socket (2) | Connect event error. Windows error code 10061: Nie mona nawiza poczenia, poniewa komputer docelowy aktywnie go odmawia. | 2020-06-01 13:19:08.558 * DTC Client socket (2) | CloseSocket call. | 2020-06-01 13:19:08.559 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 13:19:08.559 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:08.559 DTC Client socket (2) | Closed. | 2020-06-01 13:19:08.559 DTC Client socket (0) | CloseSocket call. | 2020-06-01 13:19:08.577 Rithmic Trading | Disconnected. | 2020-06-01 13:19:08.578 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:08.578 Rithmic Trading | Port for executable: 50404 | 2020-06-01 13:19:10.582 Listening socket (1484). Port 50404 | Closed. | 2020-06-01 13:19:10.582 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 13:19:10.584 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50404. Current folder: C:\SierraChart\Rim | 2020-06-01 13:19:10.612 DTC Client socket (1) | Close event error. Windows error code 10053: Nawizane poczenie zostao przerwane przez oprogramowanie zainstalowane w komputerze-hocie. | 2020-06-01 13:19:11.577 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 13:19:11.577 DTC Client socket (1) | Closed. | 2020-06-01 13:19:11.577 Rithmic Trading | Bridge process is not running! | 2020-06-01 13:19:12.608 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50404 | 2020-06-01 13:19:12.608 DTC Client socket (1) | Creating socket. | 2020-06-01 13:19:12.608 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 13:19:12.608 DTC Client socket (1) | Connect event error. Windows error code 10061: Nie mona nawiza poczenia, poniewa komputer docelowy aktywnie go odmawia. | 2020-06-01 13:19:14.611 * DTC Client socket (1) | CloseSocket call. | 2020-06-01 13:19:14.611 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 13:19:14.611 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:14.611 DTC Client socket (1) | Closed. | 2020-06-01 13:19:14.611 DTC Client socket (0) | CloseSocket call. | 2020-06-01 13:19:14.625 Rithmic Trading | Disconnected. | 2020-06-01 13:19:14.625 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:14.625 Rithmic Trading | Port for executable: 50406 | 2020-06-01 13:19:16.623 Listening socket (1088). Port 50406 | Closed. | 2020-06-01 13:19:16.623 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 13:19:16.626 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50406. Current folder: C:\SierraChart\Rim | 2020-06-01 13:19:16.657 Rithmic Trading | Bridge process is running. | 2020-06-01 13:19:18.648 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50406 | 2020-06-01 13:19:18.648 DTC Client socket (1) | Creating socket. | 2020-06-01 13:19:18.649 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 13:19:18.649 Rithmic Trading | Connected to server. | 2020-06-01 13:19:18.651 Rithmic Trading | Starting socket receive thread. | 2020-06-01 13:19:18.651 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 13:19:18.655 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 13:19:18.656 Rithmic Trading | Sending logon request message. | 2020-06-01 13:19:18.656 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 13:19:18.658 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 13:19:18.663 Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-01 13:19:18.663 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 13:19:19.842 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 13:19:20.465 Rithmic Trading | Received logon response. | 2020-06-01 13:19:20.466 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 13:19:20.466 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 13:19:20.466 Rithmic Trading | Logon error received from server | 2020-06-01 13:19:20.466 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 13:19:20.466 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:20.466 DTC Client socket (1) | CloseSocket call. | 2020-06-01 13:19:20.517 Rithmic Trading | Disconnected. | 2020-06-01 13:19:20.517 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:20.517 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 13:19:20.517 Rithmic Trading | Port for executable: 50421 | 2020-06-01 13:19:22.518 Listening socket (652). Port 50421 | Closed. | 2020-06-01 13:19:22.518 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 13:19:22.522 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50421. Current folder: C:\SierraChart\Rim | 2020-06-01 13:19:22.553 Rithmic Trading | Bridge process is not running! | 2020-06-01 13:19:24.542 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50421 | 2020-06-01 13:19:24.542 DTC Client socket (2) | Creating socket. | 2020-06-01 13:19:24.543 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-01 13:19:24.543 DTC Client socket (2) | Connect event error. Windows error code 10061: Nie mona nawiza poczenia, poniewa komputer docelowy aktywnie go odmawia. | 2020-06-01 13:19:26.546 * DTC Client socket (2) | CloseSocket call. | 2020-06-01 13:19:26.546 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 13:19:26.546 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:26.546 DTC Client socket (2) | Closed. | 2020-06-01 13:19:26.546 DTC Client socket (0) | CloseSocket call. | 2020-06-01 13:19:26.555 Rithmic Trading | Disconnected. | 2020-06-01 13:19:26.555 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 13:19:26.555 ------------------------------------------------------------ IP: 5.173.112.141 (Poland) |
| [2020-06-01 17:13:17] |
| John - SC Support - Posts: 48568 |
Refer to the following information: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
