Date/Time: Mon, 13 May 2024 00:12:37 +0000
Access to v1310 and scwbf spreadsheets
View Count: 545
[2020-06-01 13:42:09] |
Sawtooth - Posts: 3995 |
Have you locked out v1310? (I keep an old installation of it.) I need to access an old system for a former client. The .scwbf that is associated with a chart converts to .scss but a separate referenced .scwbf file does not convert because it is not associated with a chart via a spreadsheet study. And it's not possible for me to access it because I can't log into v1310. Please advise. |
[2020-06-01 18:14:37] |
Yes it has been "locked out" in a sense but you should still be able to start version 1310 and open a spreadsheet. It has been a long time since we have used that version. Are you just not even able to log into it?
[2020-06-01 20:32:48] |
When I attempt to log into v1310, I get this message: 'Invalid Account Name or Password. Make sure these are correctly entered.' To confirm I haven't fat-fingered it, I copy/paste it from a document. This works on the latest versions, but not on v1310. |
[2020-06-02 05:14:04] |
It is just too late for us to be supporting this. It is just too much effort to accommodate this request.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-02 05:14:19
