Date/Time: Wed, 18 Nov 2026 09:19:12 +0000
Denali levels
View Count: 921
| [2020-06-01 13:21:39] |
| User48838 - Posts: 134 |
I have a friend using denali and he is getting 100s of levels deep, how many levels does denali provide? I am getting 100 on each side for ESM20
| [2020-06-02 05:35:26] |
There are up to 1400 levels of depth. If you are only getting hundreds, then check the following settings: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels and Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
