Date/Time: Wed, 18 Nov 2026 09:19:05 +0000
cant log in rithmic trading
View Count: 1286
[2020-06-01 11:36:37]
User298588 - Posts: 19
hi
i cant connect to rithimic, the message stated (connection error message rithimic trading/ logon erroe received from server)..
please take a looke at it
Rithmic Trading | Connected to server. | 2020-06-01 11:32:45.755
Rithmic Trading | Starting socket receive thread. | 2020-06-01 11:32:45.755
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 11:32:45.755
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 11:32:45.759
Rithmic Trading | Sending logon request message. | 2020-06-01 11:32:45.759
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 11:32:45.761
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 11:32:45.764
Rithmic Trading | Message from server: Connecting to Rithmic 04 server. | 2020-06-01 11:32:45.764
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 11:32:48.070
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 11:32:49.364
Rithmic Trading | Received logon response. | 2020-06-01 11:32:49.364
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 11:32:49.364
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 11:32:49.364
Rithmic Trading | Logon error received from server | 2020-06-01 11:32:49.364
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 11:32:49.364
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 11:32:49.364
DTC Client socket (1) | CloseSocket call. | 2020-06-01 11:32:49.379
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 11:32:49.379
Rithmic Trading | Disconnected. | 2020-06-01 11:32:49.380
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 11:32:49.380
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 11:33:08.823
DTC Client socket (1) | Closed. | 2020-06-01 11:33:08.823
thank you
[2020-06-01 16:11:56]
Refer to the following:
Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward
