Date/Time: Mon, 29 Apr 2024 18:11:34 +0000
Chart trading with IB and IQfeed as data feed
View Count: 2274
[2013-04-16 05:30:30] |
wils0n - Posts: 1 |
Is this possible? Iqfeed as data provider and send an order direct from chart to IBs TWS. I see no option to connect with the TWS if I use an external data feed. |
[2013-04-16 05:37:22] |
FGBL07 - Posts: 19 |
Yes, this can be done. You will need two installations of SC: one connected to IQFeed and one to IB. See the documentation: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html |
[2013-04-16 06:06:08] |
The answer given in post #2 is correct.
