Date/Time: Sun, 12 May 2024 17:47:56 +0000
Keyboard binding to cancel zoom in
View Count: 534
[2020-05-30 19:20:09] |
user2837 - Posts: 76 |
Alt-Z zooms in. One can cancel zoom in using Alt-T and then choosing the cancel zoom in option. Is there a direct key binding to cancel zoom in? If not, can a key binding be set up for that task?
[2020-05-30 19:29:47] |
User907968 - Posts: 802 |
global settings -> customize keyboard shortcuts -> tools -> cancel zoom in Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Date Time Of Last Edit: 2020-05-30 19:30:12
[2020-06-01 18:26:36] |
Yes, you can configure a keyboard shortcut: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-01 18:26:49
