Date/Time: Wed, 18 Nov 2026 09:19:03 +0000
NEED HELP!
View Count: 812
| [2020-05-30 13:11:55] |
| emeka101 - Posts: 11 |
When I open up my BTCUSD chart it starts lagging even after I removed all other charts from data feed
| [2020-06-01 16:17:56] |
How much of a lag are you noticing and can you please tell us the exact symbol of the chart? It could not be exactly that symbol you mentioned. That is not valid. Refer to this section to reduce bandwidth usage: Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds See if that helps. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
