Date/Time: Mon, 20 May 2024 18:37:58 +0000
Problem with chart regions
View Count: 640
[2020-05-28 21:34:57] |
User568537 - Posts: 21 |
Hi I wanted to have a study on top of the main price graph, so I moved the graph to region 2 together with all the studies which were previously displayed in region 1, shifted down to region 3 the ones which were on old region 2 and repeated the move from old region 3 to new region 4 and so on. Finally I placed a study in new region 1. Everything looked ok so I saved the study collection. Later I tried different study settings but I did not like the outcome, so I flagged the saved study collection in "Analysis" in order to restore the original configuration BUT I got this: > the study placed on region 1 is still there > the main price graph + ONLY the Volume by Price study are still in region 2 > ALL the other studies are clogged in region 3 The only way to get the chart the way I configured is to close the chartbook WITHOUT saving it and re-open it. Am I doing something wrong? Moreover I noticed that Chart trading order association lines do not show in region 2: is it normal? Thanks. |
[2020-05-28 21:41:51] |
Sorry, I forgot to mention that I am using version 2109 64-bit.
[2020-05-29 06:27:43] |
One thing to understand about Study Collections is they save studies on the chart in each of the Chart Regions and restore those. There is no saving of the main price graph or its chart region. When applying a Study Collection all studies should definitely be restored to the chart region they were previously in. If not we would have to test that particular Study Collection. First make sure you are running an up-to-date version of Sierra Chart: Software Download: Fast Update Moreover I noticed that Chart trading order association lines do not show in region 2: is it normal? We will resolve this in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-29 06:30:09
[2020-05-29 12:41:51] |
Thanks for your reply - honestly I did not understand much... But never mind, I decided do drop the indicator on top of the main graph and re-set the chart as they were originally (I do not want to make things too complicated for something not really necessary). |
