Date/Time: Fri, 17 May 2024 21:33:04 +0000
NYMEX and ICE UK data connections
View Count: 447
[2020-05-27 16:53:07] |
User690267 - Posts: 13 |
Hello, Am switching from SC/CTS T4 to SC/TT order routing. 1. Is the SC/TT available for Brent ICE UK as AMP has just informed me it isn't, is that correct? 2. If so, what data feeds & FCM will allow me to keep using SC for ICE UK Brent?(i am based in the EU) Thanks Date Time Of Last Edit: 2020-05-27 20:12:28
[2020-05-28 04:46:29] |
1. Not right now but AMP should be supporting this soon on TT. 2. You need to use the supported CQG service instead right now: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-28 08:34:34
