Date/Time: Fri, 17 May 2024 20:37:45 +0000
timer event
View Count: 571
[2020-05-26 22:02:45] |
User517464 - Posts: 7 |
How does the timer event work in ACSIL? What is the simplest and best solution to this problem? Is there any ACSIL function or study? THX for help! Example from mql4: ... // --- create a timer with a 1 second period EventSetMillisecondTimer (1000); void OnTimer () { doSG (); } |
[2020-05-27 08:48:22] |
The closest available is to use this ACSIL variable (sc.UpdateAlways): ACSIL Interface Members - Variables and Arrays: sc.UpdateAlways And adjust the chart specific Chart Update Interval to what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
