Date/Time: Mon, 29 Apr 2024 00:37:50 +0000
Intraday Treasury Yields
View Count: 2190
[2014-01-22 18:20:25] |
cazeek - Posts: 33 |
Hello, I just found that you provide data for historical treasury yields via your historical data service (thank you very much). I'm using $TNX, and I'm wondering if this and others like it will update intraday in the daily chart. Also, is there intraday data available for this or a different symbol for intraday data? Lastly, is there a difference between which of the sierra data sources I use to pull the data (b/c I'm noticing the yields are not matching exactly). Thanks for the help, Steven |
[2014-01-23 05:39:25] |
If you are using the SC Historical Data service, you can open an Intraday chart for $TNX. From what we can tell real-time data is available, and that will be made available sometime next month with the new Sierra Chart Real-time and Historical data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-09 15:35:20] |
skelcap - Posts: 139 |
I'm using SC data service with Interactive Brokers and $TNX is not updating intraday data
[2020-06-09 19:34:54] |
That symbol is part of CBOE Indices so you need to activate that exchange: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-09 19:35:11
