Date/Time: Sun, 05 May 2024 19:22:25 +0000
[User Discussion] - automatic scrolling to End of chart (Parameter)
View Count: 2282
[2013-04-16 01:34:43] |
Rainer - Posts: 108 |
At times, the Red indicator (bottom right corner of Chart) is sometimes missed (not noticed), and fail to see new Bars drawn; (have 6 monitors & ~20 charts open 24/7). Solution: Provide an additional Parameter that moves all charts to the end in a user-configurable time frame; whereby it can be set to any minute (ie. 2-minutes, 7-min or 30-min etc.) and if set to any minute, all charts would be automatically moved to the end (last live bar) after those set minutes or set to zero-minute for not be automatic (as it currently is). Can you see the same 'value' in this suggestion and be able to implement this feature in one of your upcoming releases? |
[2013-04-16 02:10:28] |
See if you can implement this as a custom study by using sc.ScrollToDateTime. At the appropriate time you would set this to the Date-Time of the last bar in the chart. Documentation: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-16 03:18:48] |
As my level of programming has not yet progressed this far..., So if any other user is able, please share with us and reply to this post. BUT I think such a simple menu-selectable-parameter within SC, would still be the better option for all round SC users (no messing around with codes and no additional studies). Unless 'Support' you have a few spare minutes and would like to post the script for this feature in the meantime.
