Date/Time: Sun, 12 May 2024 21:33:58 +0000
The current position dissapeared
View Count: 446
[2020-05-21 17:29:34] |
User261282 - Posts: 8 |
I am unable to see my current position on intraday chart. Yet it is visible on the Daily chart. That's hurting a lot, since there are very little means of tracking using TT feed. Attaching screenshots in hopes they help. |
2020-05-21 18_27_11-Sierra Chart 2102 Real Trading SC Futur.png / V - Attached On 2020-05-21 17:28:49 UTC - Size: 38 KB - 155 views 2020-05-21 18_27_33-Sierra Chart 2102 Real Trading SC Futur.png / V - Attached On 2020-05-21 17:28:54 UTC - Size: 40.02 KB - 170 views Attachment Deleted. |
[2020-05-21 18:35:18] |
You need to set the Order Fills Start Date-Time back to a time which is the same or earlier than the start of the position: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) And also make sure this is enabled: Chart Settings: Filter Initial Fills Which Are Part of Existing Position (Chart >> Chart Settings >> Trading menu) Both these are in Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
