Date/Time: Fri, 10 May 2024 17:41:33 +0000
Lock Fill Space question
View Count: 535
[2020-05-20 21:04:13] |
mikeee - Posts: 2 |
when enabling lock fill space, if there anyway to keep the chart from just not moving in either direction. or i guess i can say, can i lock the x axis? thanks. sometimes i accidentally scroll the chart a bit while clicking thru multiple charts, and it stays cut off.
[2020-05-21 09:22:44] |
No, this is not supported.
