Date/Time: Sat, 18 May 2024 04:55:25 +0000
RSI Scann
View Count: 486
[2020-05-19 14:06:08] |
Torsten Grüß - Posts: 45 |
how can I monitor many stocks for an RSI signal in 1 minute chat. Is this possible with a spreadsheet portfolio or do I have to open a chart for each stock?
[2020-05-19 19:47:52] |
If you want to see the value of the RSI at the same time for all the stocks, then you would need to have charts for each one. The charts can be hidden. You would then use the Study Summary Window to see the values. Refer to the following: Study Summary Window Otherwise, if you are just wanting to scan through the symbols and see the RSI value for each symbol one at a time, then refer to the following: Study/Chart Alerts And Scanning: Scanning for Alert Condition Across Multiple Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
