Date/Time: Sat, 18 May 2024 04:55:11 +0000
starting
View Count: 381
[2020-05-18 16:44:53] |
User274388 - Posts: 3 |
when I double click the sierra icon the computer thinks for about 5 seconds then quits, It will not produce the pop up window to start Sierra Charts. It has always worked for the past 6 months is this a computer problem or something else?
[2020-05-18 20:07:42] |
A problem like this is extremely unusual. Go to the Windows Task Manager. Do you see the SierraChart.exe process running?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-18 20:08:02
