Date/Time: Mon, 13 May 2024 15:22:16 +0000
MES Depth Bars
View Count: 604
[2020-05-18 12:37:06] |
User137699 - Posts: 6 |
Using Denali data for MES and the depth bars are not loading properly this morning. Works fine for ES. Screen shot it attached. The depth bars will load for a few minutes then stop altogether. Issue started this morning.
Date Time Of Last Edit: 2020-05-18 13:10:07
Private File |
[2020-05-18 17:31:07] |
Could you set this value to 20 and let us know if you then see the graph fully for the times you were connected to the data feed: Chart Settings: Number of Levels for Bid/Ask Depth Calculations (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-18 23:54:55] |
Tried changing the value to 20 and it did not help. I'll connect for a few hours this evening with full depth and see if the issue persists. Full depth for MES was working perfect the past few days.
[2020-05-20 15:27:23] |
Yesterday 5/19 the depth bars for MES worked all day. Depth loaded for several hours this morning, but then gaps started to appear. Never happens with ES, only MES.
[2020-05-20 22:35:17] |
We think we know the cause of this, but could you set this setting: Number of Levels for Bid/Ask Depth Calculations (Chart >> Chart Settings >> Advanced Settings 3 menu) now down to 10 and see if you then see the bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-20 22:37:38] |
If the problem is what we think it is, this will be resolved in the next prerelease coming out today. The problem is there is just a very large imbalance between the bid and the ask side with the number of levels. We see approximately 1000(Bid) versus 300(Ask). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-20 22:38:12
