Date/Time: Sat, 18 May 2024 15:24:43 +0000
Trade Order Error - CQG order update. Status: REJECTED. Text: Order request rejected.
View Count: 1026
[2020-05-18 06:47:25] |
User578161 - Posts: 5 |
Hello, I´m traying to operate in sierra chart and that comes out. Could you help me please? Trade Order Error - CQG order update. Status: REJECTED. Text: Order request rejected. Please contact customer support.[Order parameters are invalid]. Internal Order ID: 353. Service Order ID: 1176902099. Symbol: F.US.FDXMM20. Account: *** | 2020-05-18 08:37:24.842 * Thanks Date Time Of Last Edit: 2020-05-18 10:03:40
[2020-05-18 08:24:10] |
Check the settings on the Trade Window for the chart. Check the Time in Force to make sure it is correct and the Order Type: Basic Trading and the Trade Window: Trade Window Controls Most likely it is one of those settings causing the problem. What is the order type you are using? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-18 08:24:25
[2020-05-18 08:48:43] |
OKEY THANK YOU I WILL TRY i ATTACHED YOU MY ORDER DO YOU SEE SOMETHING WRONG? tHANK YOU FOR THE ATTENTION Date Time Of Last Edit: 2020-05-18 10:11:05
Private File Private File |
[2020-05-18 10:03:49] |
We are contacting CQG about this. We do not see any problem with those settings.
[2020-05-18 11:05:04] |
This is what CQG said: The trader needs to contact their FCM. They are missing MIFID required values on their account.
