Date/Time: Sat, 18 May 2024 18:02:28 +0000
No CBOT data
View Count: 529
[2020-05-17 21:59:35] |
TraderD - Posts: 56 |
Not seeing any data for CBOT treasury futures. Using IB with SC data. Please let me know asap if this can be corrected or if it's an exchange issue.
[2020-05-17 22:07:21] |
We are aware of the issue. We are looking into it.
[2020-05-17 22:11:14] |
Refer to: CBOT Data Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-17 22:41:12] |
user8888 - Posts: 159 |
Yhe YM is working. Thank you. but the 1st half and hour is missing. I've hit redownload but no good. will we be able to redownload it later? thank you |
