Date/Time: Mon, 29 Apr 2024 07:14:10 +0000
Trial verses Paid
View Count: 1080
[2014-01-21 18:06:37] |
User18766 - Posts: 3 |
I have a trial package that has a usage end date of 3-6. If I where to purchase Usage Time, would the Data Trade Service(s) 'Amp/TTnet" become enabled, as well as the other Data Trade services that are currently 'not enable on package' ?
[2014-01-21 19:26:44] |
We need to convert your account to a standard account from a Top Step Trader account and in that case the usage time will be set back to 15 days. And it will have access to all supported data and trading services.
[2014-01-26 01:23:23] |
Will my account be automaticaly converted from a Topstep Trader 'trial' account to a 'standard' account if I pay for useage before the trial period ends? Or, do I need to have you convert the 'trial' package to a 'standard' account before I pay for useage time. If yes, then what is the best way to contact you to have the accont converted? Thank you, Brad M. |
[2014-01-26 01:54:58] |
We need to convert it to a standard account ahead of time. Do you want us to proceed with that now?
