Date/Time: Sat, 11 May 2024 16:45:58 +0000
Connection problem
View Count: 443
[2020-05-15 15:25:36] |
User565831 - Posts: 4 |
hi i added credit to sierra and it is working fine however i got a demo cqg login from amp / cqg - it will not connect. it says the UN and PW are incorrect however they are definitely the right ones. i selected cqg web api as it was the only cqg option. any help would be much appreciated. andrew |
[2020-05-15 16:08:32] |
John - SC Support - Posts: 31534 |
We no longer support the use of the CQG Demo account. Refer to the information here: CQG Trading Platform Service: CQG Demo Accounts Not Supported For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
