Date/Time: Sat, 18 May 2024 13:54:02 +0000
volume per bar vs trades per bar
View Count: 2019
[2020-05-15 13:57:11] |
User996274 - Posts: 80 |
Ive looked for a definition of the difference between these 2 chart studies Could u explain the difference? Isnt vol=to amount traded? thnx |
[2020-05-15 15:02:17] |
Ackin - Posts: 1865 |
volume per bar chart bars based upon a specified amount of trading volume trades per bar This sets the number of trades or ticks per bar. Isnt vol=to amount traded?
Very simplified: Trade is a transaction, volume is the size of content (the amount of an asset). The volume is always equal to or greater than the trades. For example: You can buy / sell several contracts (volume) in one transaction (trade). ---------------- "What Is Volume?" https://www.investopedia.com/terms/v/volume.asp Date Time Of Last Edit: 2020-05-15 15:22:54
[2020-05-15 15:11:35] |
Thank you Ackin understand now |
[2020-05-17 12:34:35] |
Refer to: Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-17 12:34:36] |
