Date/Time: Sat, 18 May 2024 15:24:12 +0000
QUICKLY hide/unhide bottom-screen studies
View Count: 710
[2020-05-15 13:12:35] |
User766076 - Posts: 3 |
Hi I need to hide/unhide the bottom studies many times, while still preserving the studies on the main (chart) window. Clicking and selecting "hide" one by one is time consuming, even selecting different templates in the analysis menu is not really comfortable if repeated many times. Wanted to create a keyboard shortcut, but it can only be assigned for all the studies alltogether. In TradingView platform I can switch the bottom-screen studies on/off quickly by simply double-clicking anywhere in the chart window, how can I do it in Sierra please? Thanks in advance |
[2020-05-16 03:17:10] |
This is not supported but you can set keyboard shortcuts for Study Collections as it sounds like you already know.
[2020-05-16 09:12:54] |
Ackin - Posts: 1865 |
User766076) How many studies do you use in the chart? It is possible to create a script or study for this. |
[2020-05-18 14:23:15] |
I tried to do so - I named my study collections as "1" and "2" and assigned keyboard shortcuts but it does not work. Then I named them "Study Collection 1" and "Study Collection 2" (like the shortcut list prompts) and no way again. I am still able to switch them from Analysis menu by mouse clicking. Please tell me how to create a shortcut correctly, what am I doing wrong? Thank you
