Date/Time: Fri, 10 May 2024 02:18:47 +0000
after version update all Sierra Custom Studies crash(CPU Exception)
View Count: 511
[2020-05-15 13:00:58] |
User569257 - Posts: 10 |
Hi all, after updating to version 2102 all the Sierra Custom Studies Crash. With message "Custom Study Weekly High Low and ECVI VWAP" caused CPU Exception) best regards, |
[2020-05-15 13:10:19] |
Refer to: Notice: Study Exceptions in New Versions and Code Efficiency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-15 16:40:58] |
thanks, that helped
