Date/Time: Sun, 12 May 2024 09:15:10 +0000
[Programming Help] - Symbol is unknown
View Count: 443
[2020-05-15 11:39:11] |
User578161 - Posts: 5 |
Hello, i tried to connect to mini Dax and this error ocurred. Could you give me some advice Thank you |
dax error.PNG / V - Attached On 2020-05-15 11:38:39 UTC - Size: 18.42 KB - 176 views |
[2020-05-15 11:53:43] |
That is the wrong year for the symbol. You need to open the symbol for the year 2020.
[2020-05-15 12:36:47] |
ouuu thanks for the support But how can I do to have live intraday data of the mini dax future? I can only see the historical data Thank you for you patient |
