Date/Time: Fri, 10 May 2024 12:24:18 +0000
APP does not open sierra
View Count: 460
[2020-05-15 09:17:53] |
User274388 - Posts: 3 |
The APP that starts sierra on my computer will not open sierra today
[2020-05-15 09:44:01] |
What do you mean by "APP"?
[2020-05-15 10:26:11] |
The icon on my main computer screen that has always started sierra charts won't open it up today
[2020-05-15 10:56:39] |
Go to this folder on your computer: C:\SierraChart\ And then run the SierraChart_64.exe file from that location. And make sure Sierra Chart is not already running. Maybe it is running and you do not notice it on the taskbar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
