Date/Time: Mon, 13 May 2024 18:21:23 +0000
Execution with same size across different charts
View Count: 500
[2020-05-14 22:55:55] |
nosast - Posts: 290 |
I'm using 3 clip sizes per hotbutton in controlbar or keyboard shortcut. Works good! I have usually 4 charts including DOM open I will execute out of. Let's say I have DOM as active window and change the size via hotbutton. When I now change to another chart with same symbol and chart trading on the new size is not set up. I need to do the hotbutton click for each window to have consistent size across all charts. Would be nice to have the option to use this with an global setting or per symbol setting for my use case. Just hit the hotbutton and know it's changed in every window and I can enter via another hotbutton and just don't need to mess around with the size. Anyway to do this? |
[2020-05-15 06:23:50] |
This is supported. Refer to: Basic Trading and the Trade Window: Trade Window Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-15 08:50:31] |
Awesome. Thanks!
