Date/Time: Fri, 26 Apr 2024 22:55:12 +0000
Delayed Data
View Count: 595
[2020-05-14 12:49:11] |
SurfTrader - Posts: 68 |
Hi I reset my computer and deleted SC along with everything. Reinstalled this morning and my data is showing delayed. How do I fix this?
[2020-05-14 14:25:11] |
It appears that your Data/Trade Service Settings are set to SC Data - All Services. Since you are not signed up for any Real-Time Data from Sierra Chart, then you would be getting the Delayed Streaming Data. This is correct functioning. If you have another data/trading source then you would need to connect to that source in the Data/Trade Service Settings. You will find the links to the vendors we work along with the specific Setup Instructions for each, within this section of the documentation: https://www.sierrachart.com/index.php?page=doc/Contents.php#SupportedDataAndTradingServices For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-14 18:00:16] |
ok got it. Didnt realize I need to set that up again.
