Date/Time: Wed, 18 Nov 2026 08:55:09 +0000
Exchanged supported spread trading using AMP+Rithmic
View Count: 1044
| [2020-05-14 04:59:38] |
| User694592 - Posts: 6 |
I have several questions: 1. Can I trade exchange supported spread using AMP Futures+Rithmic? If not, what should I do to trade it using Sierra Chart? (I trade only Natural Gas Futures calendar spread with simple two legs). Do I need to change my broker or data feed? 2. Do I need to CME bundle package to trade it? Currently I use Nymex only package as I trade /NG only. 3. I tried to open exchange supported spread chart on Sierra Chart (using Sierra Chart data feed, instead of Rithmic). I think it's /NG July - August spread chart but it looks very illiquid and DOM's empty. Is this accurate spread chart we trade? (Pls see attached image files) Date Time Of Last Edit: 2020-05-14 05:01:11
| [2020-05-14 08:54:58] |
1. We have discontinued technical support for Rithmic. 2. You just need NYMEX. 3. No those are not the right spreads. You need to look at the NG spreads. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-05-14 09:25:22] |
Then if I use SC Order Routing service (Sierra Chart Order Routing Service), can I trade /NG spread using AMP Futures? Or can you suggest other brokers which can support SC? I retried to open accurate /NG spread chart. Is this accurate one? (June-July contracts pair). Pls see attached image. Still not very liquid..... I am worrying slippage. Thanks. Date Time Of Last Edit: 2020-05-14 09:27:35
| [2020-05-20 11:57:20] |
Yes you should be able to.Not sure where you are getting those symbols from. That is also not a natural gas calendar spread. Here is an example of one: NGN21-NGU21.FUT_SPREAD.NYMEX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
