Date/Time: Tue, 21 May 2024 06:42:53 +0000
Spread Dom Idea
View Count: 710
[2020-05-13 18:39:35] |
User220914 - Posts: 239 |
HI, as if you don't have enough on your plat what would be the chances of you guys putting together a spread dom or double asset/double symbol dom. simpelst would be 2 symbols one side for buy and one for sell at mkt. You click buy and it buys the fist symbosl and sells the second Click sell and it sells the first symbol and buys the second one. thanks in advance. obviously it could get more complicated but this would be a great start because the SPREAD INDICATOR is difficult for me to use. you could also havve a spot for qty incase someone wanted to ratio Date Time Of Last Edit: 2020-05-13 18:40:35
[2020-05-13 19:00:24] |
There is functionality like this planned but it is much more advanced. We do not know when it would be added. It is not something to wait around for.
[2020-05-18 17:36:34] |
I appreciate that you said this but instead of saying it is nothing to wait around for we are working on a very advacned complex DOM or spreader couldn't you for the time being put a very very simple one together for customers like me who are ok at this point with a rudimentary DOUBLE DOM that would allow us to just load up a x and y symbols and buy and sell them at the exact same time with mkt or limit orders? I get it what you are saying but why not try and put something simple together that we could use now? |
[2020-07-15 23:37:35] |
I appreciate that you guys have some big plans for a spread type dom. Rhtihmic has a decent model and they call it a synthetic dom. that is really all that is needed at this point or even a mkt mkt or a limit fill on 1 sends a mkt order on the other. I appreciate all time and energy you are putting into setting up all of these connections around the world, but really to set yourself above going forward we really need more execution tweaks. Instead of saying oh yes this is planned in the future is there a way to maybe just get a much much simpler way to enter simultaneous orders instantly without having to double click 2 doms? Thank you |
