Date/Time: Wed, 18 Nov 2026 08:46:53 +0000
GCM0 Gold dom calculation is incorrect
View Count: 972
| [2020-05-13 14:10:23] |
| User357195 - Posts: 204 |
SC: The calculation of the dpl for a GC chart is not correct. My live GC Gold dom for the dpl field is showing +83 and the correct amount should be a -17. It is not even close to be calculated correctly. Can you fix this? I am using a Rithmic feed into Sierra Charts. The Rithmic info is calculated correctly based up what I traded off the Sierra Chart for GCM0. Thanks. Date Time Of Last Edit: 2020-05-13 14:10:42
| [2020-05-13 19:50:05] |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
