Date/Time: Sat, 18 May 2024 08:23:24 +0000
[Programming Help] - Numbers bars calculated values- duration average
View Count: 694
[2020-05-12 17:46:42] |
User968625 - Posts: 256 |
Hello, Whenever I use the average to get the bar duration from the number bars calculated values (e.g. 20MA for bar duration), it displays zero. Can you advise how to solve this? Thanks |
[2020-05-13 00:08:09] |
Flipper - Posts: 65 |
Impossible to know what you are doing without any code shown.
[2020-05-13 13:36:04] |
thank you for offering to help I have the study Number Bars Calculated values(ID44) with the variable I want to see the average fo Bar Duration (SG30) - ID44.SG1 I tried a couple of options that both put out a zero (Text display): first, use the moving average study and chose the ID50 which chose me the list to chose from and it is there (bar duration)- Text display for a study shows 0.0 and I also tried spreadsheet formula =AVERAGE(ID44.SG30[0:-10]- Text display for a study shows 0.0 I think maybe it has to do with the number format of the Bar duration Date Time Of Last Edit: 2020-05-13 13:38:13
[2020-05-13 14:26:09] |
Ackin - Posts: 1865 |
I would create a study for you, but in another thread you wrote me that you don't like third-party DLLs. "Time" needs to be converted to seconds. Moving average cannot work with this information. You can wait, if @tomgilb answers you via Spreadsheets, that should also be possible . |
[2020-05-13 14:34:19] |
Thanks, Ackin, Yes, I would wait for a native SC solution. I hope someone can help. have a wonderful day and thanks for the offer
Date Time Of Last Edit: 2020-05-13 14:45:24
[2020-05-13 14:39:29] |
Native SC solution: 1) Study Numbers bars Calculated Values Total Volume SG13 Volume/Sec SG36 2) Study Study Subgraphs Divide/Ratio - Input1 SG13 from Numbers bars study - Input1 SG36 from Numbers bars study "Second result" send to Moving averages study as source (based on) have a wonderful day
Thanks, you too
Date Time Of Last Edit: 2020-05-13 14:43:16
[2020-05-13 14:46:27] |
Yes, Thank you. I also found that there is a study called "Bar time duration" that when you adjust the setting for value format to time then it works. you are great. thank you
