Date/Time: Wed, 18 Nov 2026 08:46:54 +0000
Chart value cross hairs.
View Count: 1122
[2020-05-12 03:32:43]
User144031 - Posts: 7
Not sure how it has happened. When I have chart value on a high time frame chart all the lower time frame charts move to the position of the crosshairs position on the chart with the higher time frame. How can I disable this please.
[2020-05-12 09:48:30]
User75002 - Posts: 117
try under Tools, uncheck Synchronize Charts (CTRL-Shift-S).
https://www.sierrachart.com/index.php?page=doc/Tools.html#SynchronizeCharts
[2020-05-12 11:30:09]
Yes the answer given in post #2 is correct.
