Date/Time: Wed, 18 Nov 2026 08:46:49 +0000
Sierra Chart Datafeed
View Count: 935
| [2020-05-11 16:52:09] |
| User730867 - Posts: 16 |
Dear Support, I want to use your datafeed with AMP. However I'm ONLY interested in EUREX and I do not want CME data. So I have two questions: 1. I just funded my account with AMP and I don't understand which option I should chose (see image attached). I'm not intereted in any of the datafeed on their list, I want YOUR datafeed. Should I chose "DISABLE All Exchange Data" and then activate your datafeed from Sierra Chart ? 2. Should I pay the datafeed (25 USD for 20 symbols) and the exchange fees (21 USD for EUREX non pro) through Sierra Chart ? Many thanks and kind regards. |
| Attachment Deleted. |
| [2020-05-11 20:22:38] |
Yes for EUREX you would need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed 2. Should I pay the datafeed (25 USD for 20 symbols) and the exchange fees (21 USD for EUREX non pro) through Sierra Chart ? And in this case if you want to trade on EUREX you can use the Sierra Chart Order Routing Service as well: Sierra Chart Order Routing Service You can also use CQG for EUREX data and trading: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-11 20:23:57
| [2020-05-11 23:25:52] |
Thank you for your answer. Can you tell what option I should chose in the image attached in my previous post ? Should I chose "DISABLE All Exchange Data" ? I'm not sure how to proceed. |
| [2020-05-12 00:08:50] |
Yes you would want to use Disable All Exchange Data. And if you want to use the Sierra Chart order routing service, complete this form: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-12 00:09:19
| [2020-05-12 09:08:26] |
Many thanks for your answer. I have two last questions. a) are bid/ask volume accurate for EUREX ? b) If I place a limit bid order below market, then I lose connectivity for whatever reason and the market goes down, am I getting filled on my resting bid order ? A more exact question is, where is my order standing ? Is it on my computer or on some server/at the exchange ? |
| [2020-05-12 11:31:58] |
1. All we can say is reasonably accurate. 2. Yes. It will be at the exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
