Date/Time: Sun, 19 May 2024 16:09:45 +0000
Best setup for a European trading futures
View Count: 846
[2020-05-11 12:40:10] |
A77 - Posts: 8 |
Hi, I'm new here and I'm considering becoming a subscriber of Sierra Charts. I'm currently located in Europe and I'm looking for a setup where my broker has servers located in Europe and my data feed also has servers in Europe. That way I don't have to needlessly get delay by having to receive data from the U.S back and forth. Does anybody know if I can choose which servers CQG data feed is coming from? Thank you so much. Date Time Of Last Edit: 2020-05-11 14:40:25
[2020-05-11 20:05:56] |
What exchanges do you require data from and do you trade on? With CQG the server is automatically selected and it is based upon your location so the nearest server should be used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-11 20:06:10
[2020-05-11 20:14:05] |
A77 - Posts: 8 |
Looking for Eurex, in other words German index futures, Scandinavian futures etc. Because I'm in Europe, I want to take advantage of the location and get data feed from Europe, and also preferrably using a clearing house/broker from Europe. It sounds like this should be very easy, but finding a European broker has been surprisingly difficult. |
