Date/Time: Sun, 19 May 2024 04:55:44 +0000
Unable to load external dll in latest Sierra Chart
View Count: 569
[2020-05-09 18:47:28] |
User79074 - Posts: 105 |
For years I have been loading external dlls via loadDllFunc in my indicator code, however in the latest version of Sierra Chart the loadDllFunc c++ function no longer works. However, if I roll back to a previous Sierra Chart version it works as expected. Is this a bug or can you fix this?
[2020-05-10 00:57:32] |
We are not sure specifically what function you are referring to but this does not make sense. Any Windows API call that you make is going to continue to work the same. Sierra Chart cannot affect that.
